Subject: Re: Plung and Fed rate
Plung and Fed rate
1/11/17
AA
Hi,
we are trying to make a groove 3" width by 3/8 Depth on a MDF material
the pass depth we have it at 1/8 but using Amana flycutter 2 1/2 model RC-2251 .
what is safe feed and plunge rate would be.
Thank you.
1/11/17       #2: Plung and Fed rate ...
Wood Dust
Personally I would not do any more than a 1/16''. I also wouldn't use my fly cutter for that, I would use a 1/2'' or 3/4'' bit .
Make the last pass about .05 or so and the width of the cut on the last pass 1/4 the width of the bit for a nice clean finish.
1/11/17       #3: Plung and Fed rate ...
If you don't care about finish, use a 1/2 or 3/4 upcut bit at 18K RPM and 1000 IPM feedrate.
With the flycutter I'd go no more than 0.060 depth, 10K RPM and maybe 600 IPM or so.
Dust control will be better with the smaller diameter bit.
1/11/17       #4: Plung and Fed rate ...
Mark
This bit should be able to do the job in 1 pass fine I think. I don't use that particular tool myself but it is not a typical spoil board cutter. It has some relief under the shaft at the bottom of the tool. You can't plunge right down with it all the way to 3/8 depth, you need to ramp in or approach from an open side.
I do MDF doors and hog out 1/4 to 3/8 in one pass easily with a 40mm diameter Amana RC-2180. I use 16000 RPM 400 IPM for my RC-2180 in MDF. Nice smooth bottom cut light sanding and primer.
I might start with those values for the RC 2180, it will probably work fine but you may need to slow the feed to 350 to allow for the larger diameter. Try a ramp angle of 25 or 30 degrees if you approach from the center, It is a little hard to tell from the picture but that should keep the solid body well out of the uncut material.
Amana Tool
1/12/17       #5: Plung and Fed rate ...
AA
Hi and Thanks to all responses,
Amana tool tech told me it can do the job but it has to ramp in at least 12", and each pass can not exceed 1/8".
Any way my software does not have the ramp option, and when i did a dray run it is really plunging and i suspected it will generate problem, so i used my 1/2" dwonshear with 16K RPM, feed rate 672 and it came clean but the only problem is it took long time.
Thank you all for your time and the valuable information.
1/12/17       #6: Plung and Fed rate ...
Shouldn't be plunging with a downcut bit.
Why only 672 IPM?
What stepover are you using?
If you use upcut roughing bit you should be able to hit close to 1000 IPM, 1500 with a 3 flute.
1/18/17       #7: Plung and Fed rate ...
Brian
You could also edit the code and add a ramp-in.
