Subject: Re: CNC trip wire Biesse Rover
5/2/17
jackie
I accidently stepped on the trip wire of my Biesse Rover 321 R and the safety system wont engage. I am down until I find a solution. Anyone ever have this happen?
5/2/17       #2: CNC trip wire Biesse Rover ...
Kirk
It's all based upon the tension of the trip wire.
At the opposite end of where the little button you pull up on to reset the wire is a "turnbuckle" for lack of a better term. Can't remember if you need to loosen or tighten it but at any rate, just mess with it to adjust the tension on the wire till you find the sweet spot and the button will stay up.
5/2/17       #3: CNC trip wire Biesse Rover ...
Wood Dust
It is all about the tension on the cable. You need to twist it so that it is in the green zone (at least on mine there is a green zone) . Then pull the pin up to re engage
2/10/18       #4: CNC trip wire Biesse Rover ...
Chevy
look at the base of the machine for a blue botton,,,,,just push it in.
