Subject: Re: Morbidelli Universal 3012 TV Aspan setup.
6/12/17
Michael M. Member
I am working with a Morbi Univ. 3012 TV. Aspan does not seem to be configured correctly. At first it only had half the spindles so I got the def file and installed it in aspan. Now the problem is the CAM environment will not select any router bits for the machining. I am using the correct width of the router but it gives me an error when it says tool assignment, routing assignment.
Warning AS000:Some routings impossible. Face/s Upper.
The setting for the router bits are set up for the top side of the panel.
When I get into the CAM page I can double click on the routing and select the correct tool and then save the file and it will run fine. Just wont automaticly select it. And it does it with all 6 bit installed.
I am using Aspan rel 9.4. Xilog Plus is 01.14.026.1006
Thanks for any help.
