Subject: Re: Fitting Size
Fitting Size
7/1/17
Mario Member
Website: sunwestwoodworks.com
Hello all, I am trying to find a push to lock fitting for a Brandt edgebander. The air line size is 8mm but I am stumped on the thread name. It is 10 mm in size but I know is not NPT. Anyone know what the thread type is called? I am sure all the European machines use the same type. Hoping to find it locally.
I would appreciate your help.
7/1/17       #2: Fitting Size ...
Dan
Most common metric threads are ISO.
The distance between threads (pitch) is used instead of the thread count for description of coarseness.
A fairly coarse pressure fitting might read
M8.00x1.25
7/1/17       #3: Fitting Size ...
Mario Member
Thanks, Dan. I am still unable to find anything using the ISO designation. There has to be another way to find it. Problem is, I don't know what to ask for. Any more ideas anyone? Thank you.
7/1/17       #4: Fitting Size ...
Johann Huck  Member
Website: http://www.themachinewarehouse.com
Mario,
If the threads are more than likely G (British Standard Pipe BSP) thread. If the threads are straight, then is it BSPP thread.
More than likely it is G1/4 of G3/8. You can easily search this online to find out.
Johann Huck
The Machine Warehouse, LLC.
704-839-6615
johann@tmwsales.com
7/1/17       #5: Fitting Size ...
I'd take a measurement of the id of the hole. Then go to a hydraulic hose supplier and talk to them about loaning you a couple of fittings for size confirmation.
7/3/17       #6: Fitting Size ...
Mario Member
Thank you all for your responses. Johann, I searched for the G3/8 and found this:
http://www.globalspec.com/SpecSearch/PartSpecs?partId={7BAD5F1A-F2DF-4C50
-BE04-907C9054FFEC}&vid=98970&comp=2213
It seems to be what I need, except it says the nominal size is 5mm. The other dimensions seem to match. The only place I could find it on was e-bay, from Honk Kong:
http://www.ebay.com/itm/1PC-FESTO-Push-in-fitting-QS-G3-8-8-186100-/29191
0261831?_trksid=p2385738.m2548.l4275
Rolled the dice and ordered two. Not a grat loss if it does not work out. Thank you very much for your input. Cheers!
