Subject: Re: cutting 1 inch material
7/15/17
scott
I bought a bunch of 1 inch melamine for next to nothing and I want to build some shelving units for my shop with it. I was wondering what feed rate, what bit and how many passes are recommended for 1 inch thick particle core melamine? thanks
7/15/17       #2: cutting 1 inch material ...
jerry Member
You don't say what kind of CNC you have and what size bits it can take.
7/15/17       #3: cutting 1 inch material ...
Sorry, I have a Scm Pratix 48 and usually but with 3/8 2 flute compression bits, sometimes I use 3 flute. Thanks
7/16/17       #4: cutting 1 inch material ...
Try 3 flute compression, 2 passes equal depth 16000-18000rpm at 1200ipm.
7/18/17       #5: cutting 1 inch material ...
Brian
1/2in comp spiral 3 edges 18k rpm 1200+ federate. 1 pass. chipload 0.022
