Subject: Re: CV adding wood top with hardwood edge
10/6/17
Kevin Berthelot
I see TOPS on the left of my screen, but it isn't set up. Can someone explain how to set this up?
10/6/17       #2: CV adding wood top with hardwood ed ...
Jared Emery
Like most CV questions, the answer is long and complex. Do you have eSupport? It's a much better resource. If not, the quick version is that you need to 1: make sure your countertop materials have been entered in CV's material manager, 2: set up a material schedule for your countertop, telling it what materials you use for each countertop part, and 3: make a new countertop construction method by answering the countertop wizard's questions, which tells it how you build your tops.
Once you've started a job and chosen the material schedule and construction method you just made, you can drop a few cabinets onto a wall, go into Tops, and try Autobuild tops. Depending on how you build your cabinets, it might work, or it might need adjustment. You can also just go into Tops, create a new top, and draw it out with CV's cad tools.
