Subject: Re: EP0 Grease
EP0 Grease
12/7/17
Knick  Member
Website: cmsdisplays.com
We have a Biesse CNC that the auto greaser calls for EP0 grease. I can only find it in 5 gal pails, but I only need 2 qts. anyone have a source for smaller amounts?
12/7/17       #2: EP0 Grease ...
kirk
I believe that Better Vacuum Cups @ greenbvc.com carries this. Mike (the owner) is a former Biesse tech and if he doesn't have it, he'll tell you where to get it or else what a comparable substitute will be.
12/7/17       #3: EP0 Grease ...
Knick  Member
Kirk
thanks for the quick response I will give Mike a call.
thanks again!
12/7/17       #4: EP0 Grease ...
Mark T
Screenshot below is the chart in a Biesse Rover 30 manual depicting the alternate equivalents. Also, there is very little difference between EP0 and EP1 grease, the "1" references the grease is slightly stiffer which can be an advantage on older machines with some wear. The key here is if the machine is under warranty you would always want to use the recommended grease.
Mark T.
View higher quality, full size image (2688 X 1512)
12/7/17       #5: EP0 Grease ...
Knick  Member
Mark
I agree, I dont want to take a chance on the auto greaser not being able to push it through the tiny little lines. Then have to go back and clean it all out.
12/7/17       #6: EP0 Grease ...
Andrew
we have it as well, but Mike is also a resource that we purchase from..we also carry the metaflux grease for the spindle
regards
Andrew
12/9/17       #7: EP0 Grease ...
Derrek
Use only the specified grease. That "being a little stiffer" will clog the small diameter long lines that feed your grease points. It is a huge pain to unclog, I know from personal experience.
The reason you can only get it in a pale from manufacturers is that its a zero weight grease and runs out of the grease guns, so they don't put it in small tubes. Guys like BVC are.repackaging it. A few years back I called mobile oil and an hour later was talki g to and industrial lubricant engineer. She gave me the run down and education on grease
12/9/17       #8: EP0 Grease ...
Mark T.
Apologies, I should have clarified. Some, machines do not have auto lube pumps nor the associated grease lines. In those instances where the fitting is directly mounted to the bearing the viscosity of the grease is less critical. Rails and bearing manufacturers will typically specify a range of viscosity of grease their bearings will perform with.
12/11/17       #9: EP0 Grease ...
DannyB
1 and 2 are easily available from Zoro in 13.7oz really cheap, which means 1 or 2 quarts (which is like 4 cartridges) isn't that expensive (< 20 bucks)
0 is a bit harder to find. Most cartridges are expensive (15-20 bucks each).
From what i see, it may actually be cheaper to buy a 5 gallon pail.
Depending on how much a chance you want to take, you can also often get it from tractor supply houses (because it's used in gearboxes, etc) in quarts.
12/14/17       #10: EP0 Grease ...
Pdub
I found someone on Ebay repackaging it into tubes. Price was reasonable. It would take me decades to go through 5 gal.
