Subject: Re: Splitting a spoilboard
1/26/18
Jack  Member
Hi all,
I work with a Morbidelli 3615 nesting router with a 12 x 5 foot vacuum table. The bed is aluminium with a 20mm grid system for the gasket and the CNC has a offload function.
My question is how could I split the spoilboard into 2 separate boards to make accessing the bed and gasket below easier?
I'm worried that the spoilboards might move if they are 2 separate boards instead of the 1 large board during the offload. The newer models have a grid of countersunk holes in the spoilboard and fix it to the bed.
Maybe I'm overthinking this
1/26/18       #2: Splitting a spoilboard ...
Sure you can split it.
If you can screw it down, better. A buddy of mine drilled and tapped holes in his CNC to do so.
I have 2 5x5 tables, independent boards on each and a 5X10 on top of that. Works great.
2/2/18       #3: Splitting a spoilboard ...
Kevin M Member
We have been bolting down the spoil-board since day one 2012. Not bolting it down exposes you to the movement of the board when sweeping happens. Keep in mind if the spoil-board moves the potential for the gasket foam can be moved, compromising the vacuum zones.
Your phenolic board is probably not one piece. Ours is two plates about 74" long. We separate the spoil-board there. The seam in the phenolic is commonly a void in the vacuum system. If your phenolic board is not predrilled you would do well to use your machine to predrill as you will need the geometry to then drill the spoil-board accordingly. We bolt down with plastic bolt and washers. The countersink is flat to 1/8" from the bottom. After bolting down we plug the hole with a plug made from similar material.
