Subject: Re: Biesse Rover 23 - Failure Z Axis - Code Ad0
2/9/18
Ejeoalo Member
Help with Rover 23 Biesse
When we try to move the Z Axis, the servopack Yaskawa shows Ad0 error code.
Yaskawa Servopack
SGDB-15VN
2/9/18       #2: Biesse Rover 23 - Failure Z Axis - ...
Chevy
check your basics
air pressure
check all the "eyes" sensors above the spindle ,,that model should be es919
clean the track the spindle rides on,,
check the skirt around the spindle,,,(the black thing that has long bristles)
2/10/18       #3: Biesse Rover 23 - Failure Z Axis - ...
Johann Huck  Member
Website: http://www.themachinewarehouse.com
I would check the connector coming into the drive. It depends on the setup but you have a multi pin connector on 1CN and 2CN. 1CN is usually the resolver/encoder feedback. With the power off, unplug this connector and blow it out including on the drive and then plug it back into the drive. Also check the cables going to the motor. You will have a power cable and an encoder cable. Make sure they aren't damaged. Then power the machine back on and see if that fixes it. With the Yaskawa servopacks. I find those connectors they use are small and tend to loose connection. 90% of the time unplugging them and blowing them out and then re-plugging them in fixes most problems. If that does, it would be ideal to hookup a laptop to the drive to see exactly the error message that it is giving. It could be the servo drive or encoder is going bad.
Johann Huck
The Machine Warehouse, LLC.
704-839-6615
johann@tmwsales.com
2/10/18       #4: Biesse Rover 23 - Failure Z Axis - ...
Johann Huck  Member
When checking the documentation of that drive. "Ad0" error means position error pulse overflow. Meaning the encoder pulses have exceeded a value programmed into the drive. So this tells me that you are having a problem with the encoder or cable. It is also possible the servo drive is going bad and not controlling position like it should.
2/10/18       #5: Biesse Rover 23 - Failure Z Axis - ...
Chevy
Grab a meter and check the basics ,,,,and clean,without compressed air,,,I have yet to see a bad yask from the nc1000,,,,get pnumetics and electrical,,,but it’s difficult to trouble shoot without being there,,,I have schematics and pnumatics somewhere if u need them
