Subject: Re: face frames
face frames
3/15/18
chris
Is anyone making 1 piece MDF face frames on their nesting machine? Less work than traditional methods?
3/15/18       #2: face frames ...
Greg Member
We do frames on our CNC occasionally, but I find I can't cut a smile width less than 2 or 3" or else we don't get a nice edge.
3/15/18       #3: face frames ...
Greg Member
Smile was supposed to be stile. :)
3/15/18       #4: face frames ...
chris
Hi Greg,
How do you deal with the inside corners? Do you cut right through or onion skin?
3/17/18       #5: face frames ...
Mark
I cut paint grade raised or shaker panels of any profile right in the frame fairly often, sometimes beaded sometimes square edge face frames. Use a 1/8 inch straight 3 flute bit to part the doors from the frame, it may take 6 or 7 passes to separate the frame from the door. Try a MSC #:09653429. I have a few bead cutters for the doors and sharpen the inside corners with a 1/16 inch ball mill, 25 or 30 passes makes sharper corners than the paint will leave and takes 30 seconds or less per corner, depending on your machine and the finish you want.
It takes a bit of machine time, but compared to making them from wood parts, no contest. Use a high quality MDF and good primer.
I just cut 40 profiled frames last month with divided lights. Sharp cornered double beaded sticking 3/4 inch wide, 1-1/2 inch stiles monolithic MDF, they looked beautiful right off the CNC.
3/18/18       #6: face frames ...
Cs
Sounds interesting. Do you use a parametric program for cutting the frames and doors? What software are you using?
3/19/18       #7: face frames ...
Greg Member
Hi Chris, the inside corners have a raid the diameter of the router bit in the CNC. If we want to square it we need to chisel or sand it square.
3/19/18       #8: face frames ...
Mark
Yes, parametric, and Alphacam. Cutting the corners with the radius of the bit is fine, and gives a more modern look. Definetly quicker and easier. If you want a classical look you need to sharpen the corners.
