Subject: Re: Best router bit to cut expanded polyethylene foam?
3/27/18
Icestation2
Can someone advise on the best router bit to use to cut 30mm thickness expanded polyethylene foam – Ethafoam, Stratocell? I’m surprised by how few router bits there seems to be on the market which are designed to cut this type of material. Toolstoday sells a range. I guess the main issues are whether upcut or downcut is best. And whether or not using MDF as a spoil board would likely dull the cutting edge?
3/27/18       #2: Best router bit to cut expanded pol ...
Try Datron.
They make some pretty nice bits for foam.
Not cheap.
https://www.datron.com/tools/foam-cutting-tools.php
3/27/18       #3: Best router bit to cut expanded pol ...
Mark T
Have machined through 63.5mm (2.5" thick) polystyrene with many of the bits offered by Onsrude (embedded picture). All are designed to withstand through cuts into MDF spoils. Cut geometry is more dependent on what you want to accomplish with edge finish in regards to depth of cut.
Hope this helps
Mark T.
View higher quality, full size image (2688 X 1512)
4/23/18       #4: Best router bit to cut expanded pol ...
Salce Smith Member
Website: https://www.ricocnc.com/
CNC spare tools supply a range sizes foam mill bits for foams, EPS, EVA, etc. Hope you can find suitable bits there.
View higher quality, full size image (730 X 496)
View higher quality, full size image (550 X 427)
http://www.cncsparetools.com/cnc-foam-milling-cutter-bits.html
4/23/18       #5: Best router bit to cut expanded pol ...
I cut some foam a few years ago. Cut like butter. Fast spiral from Vortex. 4100 series.
