Subject: Re: Multiple vacuum pumps
4/28/18
Good morning all.
For those of you with multiple vacuum pumps, do you plumb them into a common plenum or separately?
I'm thinking about plumbing my 3 pumps into such a setup and just use spring loaded check valves to isolate them.
Any ideas and or comments welcome.
4/28/18       #2: Multiple vacuum pumps ...
Why do you have 3 pumps?
I currently have 4, 7 if you count veneer pumps. I am working on dropping it to 2. One main pump and one backup.
4/28/18       #3: Multiple vacuum pumps ...
Derrek
I have 2 pumps on my CNC. I ave them located in a remote location to keep the noise and heat out of the shop. Each pump is wired separately and we have a 4” pvc pipe running to the aching. Each pump is connected via the factory supplied vac hose to a 45 degree fitting with a inexpensive pvc gate valve from Lowe’s. If we have a pump down we can isolate with a twist of the valve.
4/29/18       #4: Multiple vacuum pumps ...
Rob Young  Member
Website: http://www.cmsrepair.com
Derrek's response is a common way to hook up two vacuum pumps. Many shops put their pumps in a remote location for the reasons he listed.
4/29/18       #5: Multiple vacuum pumps ...
Thanks all.
4/30/18       #6: Multiple vacuum pumps ...
Derrek
I was wrong I don’t have gate valves on this set up the pumps have built in n check valves. See vid o below. My old set up we had gate valves
Video
4/30/18       #7: Multiple vacuum pumps ...
Thanks again.
4/30/18       #8: Multiple vacuum pumps ...
Bill Member
Derrek,
Great video thanks for sharing.
I looked at those Busch Mink Pumps. Are you using them on a pod and rail table or a nested table?
4/30/18       #9: Multiple vacuum pumps ...
Derrek
They came with my Biesse Rover S, which is a 4x8 flat table. We run both but see very little difference when we run 1. The have been great zero maintenance and I feel they are quieter than the Becker
4/30/18       #10: Multiple vacuum pumps ...
How many “ of Hg do you see?
