Subject: Re: first CNC router, where should my zero position be?
4/30/18
Norm Grimberg  Member
Website: http://mdaltd.ca
I have homing switches and I'm unsure if my zero should be right after they are done doing there homing or if the zero is supposed to be the center of my build volume?
4/30/18       #2: first CNC router, where should my z ...
Sounds like an easy question, but not so much.
What kind of machine?
What software?
Mine zeros at the limit switches but I use a machine offset to set 0,0,0 at the lower left corner top of spoilboard before I cut anything. This is handled by the post processor.
4/30/18       #3: first CNC router, where should my z ...
Most machines home to machine zero, which is not the same as program zero. For every move the machine makes,it does the math based on all the offsets from machine zero.
5/8/18       #4: first CNC router, where should my z ...
Cherry Stylecnc Member
Website: http://www.stylecnc.com
You can try as my words: 1. Open the machine, and then ALL AXIS HOME, the spindle will move to left front of machine. 2. move the spindle over your material, down Z axis, can touch the material. 3. XYZ all zero. then it's zero position now. 4.Choose the file you want to do, the machine can work.
5/15/18       #5: first CNC router, where should my z ...
leon513  Member
Website: http://www.hicasmachinery.com
1) Servo motor or some stepper motor has Z-phase pulse, one pulse per circle. Some are called origin pulse, index pulse etc.
2) When you want to find the origin, slow down, the hardware captures this pulse, and with the reference point, the others are easy to handle.
3) Only when it is necessary to return to the zero point (turn on), it will only return to zero. There will be no return to zero afterwards. There is usually a sensor called the near zero point sensor or called the origin sensor before the zero return. When this sensor has a signal, it will look for Z phase. pulse.
4/28/21       #6: first CNC router, where should my z ...
murat Member
Website: https://nesto.com.tr/en/
Most machine doing that, no problem
https://www.woodweb.com/cgi-bin/forums/cnc.pl?read=822965&session_id=
