Subject: Re: busellato jet 3006 won't reset
5/17/18
Ray
jet 3006 had things running making some test panels everything seamed normal loaded the panel applied the vacuum went to hit the reset blue button on the tower and it never set, just two left blinking green lights.
screen says the photocell needs to be reset tried that it all checks out even used a ohms meter to verify the connection. also checked all the switches. did a complete reboot goes back to the same issue. checked safety mats. obviously something is not making a connection but what ??
5/17/18       #2: busellato jet 3006 won't reset ...
Check all the safeties, switches, beams, trip wires.
5/17/18       #3: busellato jet 3006 won't reset ...
Ray
Thanks for the response, the safety mat has a short in it and needs to be replaced.
