Subject: Re: Woodwop 5.0 and woodnest
5/18/18
Anthony Member
Hello all hope your having a great day
I am closing a deal on a cnc router a weeke vantage 38l 2009 and i am trying to use the woodnest software to cut my pannels but i am getting errors and the cnc owner never used woodnest any one can help me with that ?? Or mabe to help me choose a different software for nesting ?? Thank u in advance
View higher quality, full size image (4160 X 725)
5/18/18       #2: Woodwop 5.0 and woodnest ...
Chevy
i have seen this error before ,,,open up woodwop 5 then woodnest,,,inside raw plates tab,,make sure you have x y and z values ,,,if those fields are empty,,you will recieve the error
5/19/18       #3: Woodwop 5.0 and woodnest ...
Chevy
the nesting functions of woodwop /wood nest are pretty powerful,,however there is no program on earth like cabinet vision,, it is the most powerful and the most expensive,,alphacam is also very powerful and very expensive,,i would spend the time and train on the software you have access to..if you have access to a cad program,,woodwop and woodnest,,,this is all you need.,,
just my opinion
free cad programs out there
-Nanocad
-draftsight
5/19/18       #4: Woodwop 5.0 and woodnest ...
Anthony Member
Thank you so much Chevy for your response i will try it on monday and check if it will work .
5/20/18       #5: Woodwop 5.0 and woodnest ...
Chevy
No worries at all...
5/20/18       #6: Woodwop 5.0 and woodnest ...
katz
sory Chevy ,but cv nesting is not bad,but not so good
its have no cleaver optimize to chose the correct order of cuing parts,and algorithm to calculate correct entry point
the new generation of nesting ,no need onion skin
no need big vacuum pump
need good algorithim
5/20/18       #7: Woodwop 5.0 and woodnest ...
Chevy
so right,,,
5/23/18       #8: Woodwop 5.0 and woodnest ...
anthonyG Member
the problem was that i cant use this software on the machine pc i need a seperate laptop or pc to use it as well as bpp5
thank you for your help
