Subject: Re: Cutting Speeds
Cutting Speeds
6/3/18
Bob
We are adding a second nested router. The first had a 10hp spindle and we cut at 600 ipm. The second has a 15 hp spindle. Looking at tooling available I can go to a three flute and go ~1100 ipm. I’d like to speed things up.
Who has experience with this? Can you maintain accuracy?
6/3/18       #2: Cutting Speeds ...
Maybe.
What material are you cutting?
What bit(s) are you using?
How long are the straight runs?
One pass or more?
How much vacuum do you have?
How good is your dust collection?
6/4/18       #3: Cutting Speeds ...
Bill Member
Mostly 3/4" plywood
We will be using Vortex 3289XP m
Up to 80"
One pass or more?
We onion skin small parts only so one pass.
28" strong
Excellent
6/4/18       #4: Cutting Speeds ...
I would use a chip breaker rather than a normal bit if you can.
I regularly go 750 IPM in 21mm baltic birch and 900 IPM in 18mm baltic birch in one pass with a 2 flute compression spiral chipbreaker so you should be fine with bb or domestic ply.
6/4/18       #5: Cutting Speeds ...
Chuck Hicks Member
You should be able to get to those feeds without a problem. We have tested our bits (2+2) at those feed rates without a problem.
View higher quality, full size image (1200 X 800)
6/4/18       #6: Cutting Speeds ...
cabinetmaker
Vacuum - we are running a Rover @ those speeds with 40hp a lot of the parts are return onion skin Vortex 3130
We actually slowed the machine down just recently for corners
