Subject: Re: Becker SV 5.1050/1-01 Vacuum Blower
7/25/18
Duane Weaver Member
I have an opportunity to purchase two 20hp Becker SV 5.1050/1-01 vacuum blowers for an Onsrud 5x12 router. Does anyone have experience with these? Are they a good option for a vacuum table?
7/25/18       #2: Becker SV 5.1050/1-01 Vacuum Blower ...
Bill Member
I did a quick search and it appears the max vacuum they can produce is 4.8". If that is true then no. You want a much higher number.
If I had a 5 x 12 table I would want a rotary screw or a liquid ring pump. 40 hp liquid rings come on the market pretty regularly. I would look for one with low hours.
Here is a Travani from a reputable seller.
Used Travani Pump
7/25/18       #3: Becker SV 5.1050/1-01 Vacuum Blower ...
Duane Weaver Member
Thanks, Bill, I appreciate your input. I think I'm going to skip on those. I am a bit new to all these vacuum ratings like h20, mbar, hgv and all but I finally did find an online calculator that compares all these and I definitely agree with you, they won't produce enough vacuum.
