Subject: Re: horizontal holes with router bit sweet spot?
8/28/18
steve Member
Anybody have experience with horizontal holes (using 90 degree aggregate) as far as cutting depths?
My machine will automatically do a helix/spiral cut for a round hole larger than the diameter of the tool but I'm wondering about depth per rotation? I can adjust ramp speed (acceleration) from 50 to 250 percent and depth per rotation but I'm smoking the with grain holes and nuking the router bit.
I'm 'drilling' a .615 hole with a .500 bit at a total depth of 2.625 into 80 percent pine, 20 percent hard wood, both cross grain and with grain holes.
8/31/18       #2: horizontal holes with router bit sw ...
Russell
Hopefully your bit is an upshear. My rule of thumb that has always worked for me is for every single rotation of the helical cut go half the diameter of the tool. So, set the pitch at .25 inch for a half inch bit. Not sure what your RPM's are or how many flutes on the bit? It makes a difference...
9/4/18       #3: horizontal holes with router bit sw ...
steve Member
Using a two flute upcut with chipbreakers (chipbreaker is for the lvl cross grain that works well) currently each rotation is at a .500" depth.
