Subject: Re: Busellato Jet 4002XL Error: Receiver 7 disconnected,Wrong type of recei
Busellato Jet 4002XL Error: Receiver 7 disconnected,Wrong type of receiver8
8/27/18
Serge Member
The Line cable was damaged from receiver6 I/O module to receiver 7(Alb24 I/O module),8(Alb16 I/O module) on moveable head. After changing the line cable, we got message error. I installed spare alb24 I/o module it didn't help. Reinstaled Genesis 2.2.5 with 2 customer floppy disk that is runing on windows NT it didn't help as well.
Can You guys help what I am doing wrong.
8/30/18       #2: Busellato Jet 4002XL Error: Receive ...
Dan
Double check that all the small dip switches on the alb24 are in the correct position. I replaced ours not long ago and the the new alb24 switches were upside down. so from top to bottom on the old one, they were 1-7, but on the new one, they went 7-1. I initially put them all in the same position, but soon realized the needed to be mirrored (left was right and right was left).
9/1/18       #3: Busellato Jet 4002XL Error: Receive ...
Serge Member
Thanks for response Dan.Yes it was problem with the small dip switches.I found on the manufacturer's website http://www.tpaspa.it/downloads/Documentazione%20e%20Manuali/TRS-IO/ENG_eTRS-IO.pdf
I/O manuals where on page 14 is table dip switches for receivers.Thanks a lot!!! Busellato works great
