Subject: Re: accu-systems hvpp
accu-systems hvpp
9/7/18
JOSEPH n MORIN Member
just bought a used dowel drill and inserter
hvvp I can not get drill to home as screen says e-stop button on I have checked and button seems to be functioning normally and panic bar at front of machine is not engaged
these two trigger the watch dog circuit
anyone know anything about these trying to get help from pillar but so far no luck
machine is 2000 model year
all machine functions work on manual mode but to get a program to run drill has to be run to home position first
you do this by e stop reset key but error comes up saying e-stop button pushed ??
9/8/18       #2: accu-systems hvpp ...
Did you verify the output of the e stop button panic bar?
9/8/18       #4: accu-systems hvpp ...
the e stop button turns off power to esr-11 relay it seems the panic bar on front has continuity unless pushed which breaks circuit not power runs thru it . but if wire is disconnected red lite comes on at safety sensor attached is sensor relay info
doc01009520180908075201.pdf
9/17/18       #5: accu-systems hvpp ...
does anyone have a wiring schematic that I could buy a copy of
machine is accu-systems hvpp model year
2000 serial #069-00-H2V4TAD
