Subject: Re: write protected error omnitech
10/31/18
Todd Member
I am getting a write protect error. It happens when I am trying to do the tool touch off. I'm in the pattern menu on line 500. when I type in any tool number and press enter or click input the error comes up in red below the input line. The key is in the unlocked position and I tried wiggling and applying pressure to get the switch to work. Is there another possibility it could be? Is there a way to test the switch in the software or with a meter?
12/10/18       #2: write protected error omnitech ...
Todd Zuercher Member
Website: http://pgrahamdunn.com
It is easy to test the key input from the software (Fanuc control). Go to the System menu (4 on keypad) then press the PWM soft key, then press the PMCDGN soft key then search for the input X4.3. That should be the input for the key lock. While watching the screen turn the on/off and see if the input is registering on the screen.
12/10/18       #3: write protected error omnitech ...
Meant to type " While watching the screen turn the KEY on/off and see if the input is registering on the screen."
