Subject: Re: CNC upgrade
CNC upgrade
12/9/18
Al  Member
I am looking into replacing our CNC. Currently we have an older Weeke. I fill it would be best for file transferring to replace the old with a newer Weeke or can we transfer files to a compatible different brand ?
Thank you in Advance
12/10/18       #2: CNC upgrade ...
Todd Zuercher Member
I am not familiar with what the file format would be for your old Weeke, but I hate to disappoint you but it is probably very unlikely that any new machine you buy will be able to use your old machine files as they are. Machine code files are usually very specific to the machine they are set up for and usually are not compatible between different machines even from the same brand, unless the machines are nearly identical.
You should be able to use the same old CAD or maybe CAM files to create new machine files for your new machine.
12/10/18       #3: CNC upgrade ...
Chad R  Member
Website: http://www.northwayind.com
We have CADCode which allows us to read MPR's and output to many different brands of machines. This is a link to a video I made for them.
https://www.youtube.com/watch?v=UQ5YjiGh6xA&t=1s
12/11/18       #4: CNC upgrade ...
Larry  Member
Thank you Gentlemen.
I am currently using Woodwop 4.0 So to transfer files to a newer system would be a challenge? Even it is was the same model CNC ? but newer.
12/12/18       #5: CNC upgrade ...
steve
woodwop 7.1 (current newest that I am aware of and using) can still open woodwop 4.0 files. that is one of the highlights listed in the woodwop literature.
90% of my files are from woodwop 5.0 and all work as they should in 7.1 although 6.1 (I think) and on has features that are NOT backward compatible.
1/22/19       #7: CNC upgrade ...
Nick Member
Website: https://www.stylecnc.com/cnc-wood-router/
May i know what model of CNC machine do you use?
For upgrading machine, we have the ATC system CNC machine, the linear auto bits changer follow with spindle, it can catch 8pcs different CNC bits for different work, no need to change bits by hand,
View higher quality, full size image (720 X 540)
Affordable Linear ATC CNC Router with Au
