Subject: Re: 3 flutes upcut rpm
3 flutes upcut rpm
12/10/18
ag Member
hi all hope your having a great day
i own a 3 flut upcut 16 mm cnc bit
what rpm should i use for this kind of bit
12/10/18       #2: 3 flutes upcut rpm ...
DOM
Depends on your machine and vacuum.
12/10/18       #3: 3 flutes upcut rpm ...
Ag Member
I have a a weeke vantage flat table
With 300x2 m3/h 2x5.5 kw vaccum pump
9kw spindle
12/10/18       #4: 3 flutes upcut rpm ...
DOM
I have a 40 hp pump so i can move fast. You prob have the spindle hp but not the vac hp to hold the parts. Id run that tool 16500RPM 1000-1200IPM all day.
12/10/18       #5: 3 flutes upcut rpm ...
Go to Onsrud's site and look it up.
12/14/18       #6: 3 flutes upcut rpm ...
Cutting length of the bit, Material thickness, and # of passes will play a big part in feed rate along with the RPM as well.
View higher quality, full size image (2304 X 1728)
