Subject: Re: Spoilboard tips
Spoilboard tips
12/22/18
Alexi Member
Hi all
I have 2 question if possibl:.
Is their any way to know for sure if my table is flat ?
I hade done a mistake and i made a groove in my spoilboard a circle 50 cm 9 mm in a 13 mm spoilboard so i have tp fix this in any way??
12/23/18       #2: Spoilboard tips ...
David Egnoski  Member
Website: http://www.richmondcabinet.com
Depending on what type of table you have you could flycut .002 or so off the surface.
If you flycut your spoilboard, that's all you should need to do.
In an emergency, I've filled cuts with Rock Hard wood filler and then flycut.
12/23/18       #4: Spoilboard tips ...
Jim
Website: http://totalcuctcnc.com
Alexi,
to determine if your table is truly flat, you will need a dial indicator mounted in a tool holder. start at your normal home 0,0 and SLOWLY bring the indicator down to the table. When it touches, bring it down about .010 to .020 more (assuming your indicator has the range to do so. set the indicator to 0 as well as your Z position. next move to other positions along the table at incremental distances bringing the z down to 0 Zero and write down what your indicator is reading. this will give you a good idea of how flat your table is.
12/24/18       #5: Spoilboard tips ...
Derrek
For filling damaged spot in a spoilboard that are not to big, use Bondo automotive body filler. 2 part so it drys/ hardens quickly and is machinable.
1/3/19       #6: Spoilboard tips ...
Matt
I'm not sure we understand what you mean.
If you merely carved up your spoilboard, just flycut it to your satisfaction or make a new spoilboard. Cutting 9mm into a 13mm spoilboard shouldnt' harm your CNC table, just the spoilboard.
If you are actually asking how to check if the CNC table itself (under the spoilboard) is flat, follow what Jim said. Put a dial indicator on it and move the spindle around the perimeter checking for any runout.
We've done that on our CNC before because we were having some unusual Z axis issues, but ours was quite flat. The problem ended up being a faulty servo drive.
