Subject: Re: Selexx Pal Error "Preset magazine counter"
12/23/18
Agustus Member
Error code 700026" please preset magazine counter number" 2004 model Siemens controllers. Anyone have a procedure to clear this code. The code appears after reloading NC and PLC.
1/14/19       #2: Selexx Pal Error "Preset magaz ...
Todd Zuercher Member
I don't have any experience with the Siemans control on those machines. But when our Omnitech machines with the Fanuc control gives a similar error code, you need to reset the tool changer, using a couple of M-codes to tell the control what tool is in the spindle and what pocket of the tool changer facing the spindle. Probably a similar codes need to be used to reset yours. It should be covered in your owners manual.
1/14/19       #4: Selexx Pal Error "Preset magaz ...
Agustus Member
Todd, you are correct. It appears I was missing a page in my manual. I was able to solve the problem after locating the missing page from another owner with Seimens controllers. Thanks for your input.
