Subject: Re: Vacuum filter
Vacuum filter
1/22/19
Good afternoon All.
We're running a Sullair rotary screw pump and are getting sludge due to MDF and PB dust.
Has anyone out there installed a pre filter for such a situation?
1/23/19       #2: Vacuum filter ...
Is there a filter now? If not then heck yea you need a filter. They are readily available with the added benefit that the filters are cheaper than the filters that come on most vacuum pumps.
1/23/19       #3: Vacuum filter ...
Yes there is one. Paper with a foam sleeve.
Still not good enough.
1/23/19       #4: Vacuum filter ...
I’d check for leaks where the filter seals and between the pump and filter housing. Should not be that way.
