Subject: Re: Servo Problem - Accusystems Dowel Insertion Machine
2/2/19
Luke Vickery Member
Website: http://www.calwoodinc.com
Hello - we have been having a continuing problem with the Z-axis servo on our machine. I'll provide a few video links. Horrible vibration in our Z-axis servo. Long story short, we've pulled apart the entire Z axis (gear, gear rack, ball screw, gear reducer), replaced the servo controller, replaced the servo, checked the wires to the servo, and checked the relay to the servo only to find out that it has nothing to do with those components. Our X axis servo is also making the same noise. I understand there is a braking mechanism inside the servos. It sounds as though this is where the noise is coming from. All of this has been done with the help from Pillar Service (formerly Accusystems) and a local, renown woodworking machinery tech. Has anybody experienced similar problems and any suggestions on a fix? Thank you.
https://youtu.be/Cj_jMwCCcQo
https://youtu.be/Fia94d11hkk
https://youtu.be/R7iDzF0JUbo
https://youtu.be/_nLtL4Drzxs
2/2/19       #2: Servo Problem - Accusystems Dowel I ...
cabinetmaker
You are going to have to check your parameters on the servopak themselves to make sure the out put is programmed for the parameters required in the specified ranges for that application
If both servo packs are having a braking problem, then you have a plc issue sending a signal to release the dynamic braking to jog.
Open your mod bus are and check all connections in the splice terninals Sounds to me a wire is loose perhaps in the 24volt emergency circuit refusing to engage the release of the brake therefore causing all this vibration while forcing the axis to move
We have a Biesse Doweler and have had no problems whatsoever. Our Rover 30 z axis motor needed a new brake and bearings. Now that was painful. Course we put in the new ball screw too. 8k poof. Same problem until the vibration from hell.
Anyway. Good luck
2/4/19       #3: Servo Problem - Accusystems Dowel I ...
yaakov
check "loop gain" parameter in yours servo pack
try decease it
