Subject: Re: Vacuum upgrade to Rotary Screw
2/11/19
Bob Member
We are currently running 2 Becker VTLF 250 Rotary Vane Pumps on our 5X8 Table. We plan on upgrading the CNC to run 5X9 soon.
I have been offered a good deal on a 25HP Quincy Rotary Screw Pump.
How much of an upgrade would this be?
Those running Rotary Screw Pumps, Do you think they perform better than the Dry Vane pumps?
2/11/19       #2: Vacuum upgrade to Rotary Screw ...
I have a 30 HP Sullair rotary screw. Use it on a 5X10 table with no issues at all.
They love to ingest MDF dust so put some extra filtration on the vacuum inlet. Talk to Solberg Filtration - they have lots of good options. We're just adding a primary filter to keep as much of the dust out as we can.
2/13/19       #3: Vacuum upgrade to Rotary Screw ...
We went from your setup to a Kaeser Rotary screw and could not be happier. It pulls deeper, holds more vacuum as you cut and less things move. A lot less.
The downside is it is more expensive to maintain. Re-cutting parts that move are expensive also.
Consider a liquid ring also. Many low hour units on the market.
2/22/19       #4: Vacuum upgrade to Rotary Screw ...
We've got a 40hp Quincy screw on a 5x10. Runs fine but oil & filter changes are expensive and we do it ourselves. Using Mobil synthetic oil from an industrial distributor.
