Subject: Re: Cutting parts
Cutting parts
4/6/19
Matthew OMeara Member
I recently bought a linear ATC 5x10 machine. I use KCD and MasterCAM.
There are a couple shops nearby that are interested in having me cut cabinet parts for them. They both use CV for their layouts but don't have the CNC version.
Is there a way to make this work without me having to buy the full CV version?
4/8/19       #3: Cutting parts ...
cabinetmaker
Have them export it to you in a dxf file then paste it into your software and assign tools to the holes and dados etc
4/9/19       #4: Cutting parts ...
That was my thought, but I'm not familiar with CV. Both are shops without CNC, so they don't have the CNC version. Does the non-CNC version of CV allow for DXF output?
4/9/19       #5: Cutting parts ...
BH Davis  Member
Matthew,
A quick online search indicates that CV does indeed export .dxf files.
.dxf stands for Drawing Exchange Format and is pretty much the universally accepted file format for getting drawings from one program to another.
4/9/19       #6: Cutting parts ...
I have a client who sends me nested sheet dxf's from CV.
Make sure your client uses the proper sheet size (49*97) and a reasonable gap from the edge and between parts. I use 0.250 and 0.450.
If they are halfway proficient with CV they should be able to name the layers as you want them.
If the files are wrong and then the parts it's their issue.
I always nest myself if I can.
4/11/19       #7: Cutting parts ...
Dan
If the cabinets are not that complex, it may be more efficient for you to do the jobs with your software, KCD and MasterCam vs relying on drawings and parts done by someone outside your office.
Remember to account for your programming time as a cost of running parts which ever way you go. Personally I would be more comfortable relying on my own software and programs.
4/11/19       #8: Cutting parts ...
For whatever reason I could never get a shop to use my dxfs in CV, they would always insist on redrawing everything in CV.
I exported in Auto Cad version 12 DXFs
From what I was told even CV to CV is problematic.
Maybe not from CV to DXF?
4/14/19       #9: Cutting parts ...
Jason Scott
I talked to the cv people about this very thing. I was told they charge extra (surprising isn’t it) for the ability to export to dxf.
4/14/19       #10: Cutting parts ...
cabinetmaker
Since this is a post about making money with your new machine, I will answer directly how we “do it”
The logic is materials and construction methods for CV. So, we redraw, and since we have the box sizes already, it’s pretty fast
In order to work your machine in your shop, you are going to have to set up a system that works for you. It’s apparent you are using KCD and obviously it works. Put together some forms or check sheets that feed you the info you need and start cutting.
4/14/19       #11: Cutting parts ...
Matthew OMeara
Jason,
Yes, that's what the shop with CV told me as well. He can export PDF's but not DXF files with his non-CNC version of CV.
I think my best bet is to simply recreate the cabinets into KCD and follow my own system. I was hoping to get DXF files, skip KCD and go straight to my MasterCAM ATP process.
It doesn't take long to recreate cabinets in KCD, but then I have to worry about making errors transposing the drawings.
4/14/19       #12: Cutting parts ...
Jason Scott
I thought KCD used enroute for ATP did they switch to mastercam?
4/14/19       #13: Cutting parts ...
Matthew OMeara
The KCD CNC version I have outputs DXF files. MasterCAM and Enroute both have ATP modules.
I bought both MasterCAM and KCD in 2011, so I'm not sure what's changed since then, but I think it's the same basic process.
I haven't paid a dime for software since 2011, so I really don't want to have to hop on the CV train and pay yearly.
