Subject: Re: SCM S15 B Questions
SCM S15 B Questions
4/6/19
Jason Balm  Member
Website: waukeecabinetworks.com
I purchased a 2012 SCM S15B used with really low use on it. We are busy setting up for the SCM tech to set up the machine in early May. I am finding it difficult to gather information I need to give to Mozaik for my post and wondered if anyone here would be willing to help me out.
I am sure all of this can be tweaked when we integrate and test, but here are the details I need specifically as it relates to this machine. (it has the standard 7 position drill and a 10 position atc)
1. Gcode Output - inches or MM?
2. Tool touch off - top of material or top of spoilboard?
3. Z value output - out put Z values as negative or positive values?
4. Need a diagram for the drill head - guessing this needs to show M-codes for both axis's and the tool position numbers?
I have also been looking for some type of user manual for Xilog Plus. If someone has a PDF file of this and is willing to share that would also be very helpful.
Lastly, If any of you use this era machine and Mozaik together, I would like to know if you have also installed the CNC Operator at the machine. I know it isn't "needed", but it sure seems like not having the machine operator need help from the office for remakes, etc has it's advantages.
Thank you in advance!
4/7/19       #2: SCM S15 B Questions ...
Chris
1. Use what ever scale you use in your shop in or mm it doesn’t not matter.
2.the tool touchoff has it own spot that does not move,it’s near the tool rack.
3.z+
4. If you open xilog plus,open the tool def tool file,there’s a little icon on top that you can hit and it will show you the diagram and tool numbers
4/8/19       #3: SCM S15 B Questions ...
yaakov
in scm like biesse like homag like tpa
you have buildin drill head optimiser no need drill diagram only diameter
4/8/19       #4: SCM S15 B Questions ...
Re 3.
Unless you are doing work that requires reference from the top of the material use spoilboard as zero and all Z references to match.
So, a 1/4 deep cut in to a 3/4 sheet of material should be at Z0.500.
4/8/19       #5: SCM S15 B Questions ...
Jason Balm  Member
Thank you for the responses guys. Much appreciated!
