Subject: Re: Architectural panels
5/1/19
Paul C Member
Here in FL the decorative Architectural wall panel business is beyond 40 million per year. What is your 3 axis router doing after your cabinet parts are cut? With coatings of stucco [fiberglass reinforced polymer] or the like and veneer and other films vacuum glued to the wave panel you made [EPS, foam, MDF]. If you custom design these simple wave/broken glass designs vs the Architectural panel big box stores, well there ya go.
7/11/19       #2: Architectural panels ...
Glenn Member
Website: http://mysticcnc.com
I am interested in textured wall panels. and found your post. Can you be more clear, I dont know what you are trying to say.
7/11/19       #3: Architectural panels ...
Paul C Member
Glenn, See what 3form is doing. Here is a sample of "broken glass" design cut into white Corian. 3d litho into MDF. Wave into MDF
View higher quality, full size image (810 X 1080)
7/11/19       #4: Architectural panels ...
Paul C Member
Glenn, if you cut some design from EPS - like a wave panel or a Mayan wall (styrofoam architectural grade) and spray it with stucco, plaster polymer etc with a rig like this. Styrocrete.com
Is that a Laguna w a 5.5kw water cooled and a DPS? Nice machine.
