Subject: Re: MPR vs NC Programming
6/25/19
Jason Rogers Member
On WEEKE routers is there anyone programming using the NC option instead of using .MPR?
If so is there a manual that defines the MACRO's used in the NC format?
6/25/19       #2: MPR vs NC Programming ...
yaakov
i not familiar with homag
but i belive its same as biesse same as Tpa
the use for nc is only 2 reason
1. dubag
2.when have 5 axiss in interpolation this cadcam not support so they let you jump over directly to nc
in all othere cases much more easy to create pp from nc to...(mpr,bpp,tcn,xxl...) then try write nc ,there nc files not simple
8/7/19       #3: MPR vs NC Programming ...
BrianZ Member
If you program a part in mpr format using easily identifiable values (things like “345”, “789”, etc - then open it in notebook as a .txt file, it will show you all the NC code. It’s tricky to figure out, that’s why the need for easy to identify values so you can recognize them and determine what the rest of the code represents.
The only time I ever use it is when I have to code for specific processing instructions in Cutrite.
