Subject: Re: Help - 2012 SCM PRATIX S15 tool change issue
7/14/19
Jason Balm  Member
Website: waukeecabinetworks.com
Any other SCM pratix owners out there that have experienced the spindle going back to the rack, entering the fork, and then just sitting there to 5-10 minutes before moving on to the next tool?? If so, what was your fix?
We've tried a deep clean on the spindle, perform regular maintenance, and checked that the output signal is there to initiate the change from the computer. The scm techs are telling me it may be a solenoid/sensor in the spindle and the fix may require a new spindle, but I'm trying to squash all possiblities before throwing down 15k.
It happens intermittently and that makes it very frustrating, because the spindle itself runs perfectly.
7/15/19       #2: Help - 2012 SCM PRATIX S15 tool cha ...
CRIS
You may have a broken wire to the changer solenoid.
7/15/19       #3: Help - 2012 SCM PRATIX S15 tool cha ...
Jason Balm  Member
We are looking into that this week with a tech in our local area. This morning I spoke with a spindle repair business in California that actually sells the SCM owned Hiteco spindle. They mentioned checking voltage and your suggestion of also is in line with this thought.
The other weird thing about this intermittent problem is I have yet to have it happen while working with melamine on the table! It has only happened while machining MDF doors, etc.
7/16/19       #4: Help - 2012 SCM PRATIX S15 tool cha ...
Roy Pierce
How often and what steps do you use to do the spindle maintenance?
Have you check that the extraction height of the drawbar is 10.8mm +/- 0.10mm?
When you open the spindle manually and the draw bar extends is it smooth, and does the extraction air blow?
When it is waiting on the tool before it raises what state is the draw bar sensor and unlock sensor showing in the i/o?
Is the electrovalve for unlocking the spindle working correctly?
7/16/19       #5: Help - 2012 SCM PRATIX S15 tool cha ...
Chris
It’s very rare that the hecto spindle has sensor issues. If anything I would check the valves that sit above the spindle. To test them go to the handheld and use the lock/unlock button and see the reaction.
8/6/19       #6: Help - 2012 SCM PRATIX S15 tool cha ...
Jason Balm  Member
The issue has been resolved. Thank you again for the advice and ideas to check.
I felt that the issue seemed to be heat related, due to it seeming to happen primarily while processing MDF doors (longer processing times between tool changes) and on days when the shop was really warm. I could run though 20-30 sheets of melamine in a day without issue on a nice day. I could run a couple sheets of MDF doors and it would present itself. If the shop was 85-90 degrees like we had a month ago, it would present itself.
I hired a local CNC service company to come look at the issue after talking it through with them. After they checked out the air valves above the spindle and various other ideas mentioned here, they removed the plastic hood at the top of the spindle to begin a deeper look and discovered a broken bolt at the top of the spindle. There are 4-M6x135mm bolts at the top of the spindle and one was broke at the top of the threads. The plate these bolts are holding down would move ever so slightly (less than .5mm) at the corner with the broken bolt with each manual lock/unlock cycle. Replaced all 4 bolts and so far we are working without issue.
The theory is this movement prevented the draw bar from dropping fully (primarily after longer machining cycles when the spindle/tooling/cone was warmer).
I would love to know how that bolt would have broke. The tech thinks it may have shipped new that way. The previous owner never experienced this issue, but he processed closets only and would have been using the drill block and cutout tooling only with minimal tool changes.
Wish me luck!
View higher quality, full size image (1440 X 1914)
