Subject: Re: Compressors
Compressors
11/21/19
Conor Devoy Member
Hi all, we have a 20 year old keiser rotary screw compressor with a 15kw motor. It runs almost all of our machines and assembly tools in a medium sized shop. It's fine but heavy on electricity. Has anyone got any experience of newer models/technology. Thanks, conor
11/21/19       #2: Compressors ...
15 kw is around 20hp I believe. We have multiple 20 hp Kaesers set up sequentially. Each one puts out a solid 100 cfm. We have been very happy with them. They are a couple years old.
11/22/19       #3: Compressors ...
yaakov
is it stop when reach the high pressure?
or just release the clutch?
i know the old models was just release the clutch ,motor still run even without load its still need high energy
11/22/19       #4: Compressors ...
Conor Devoy Member
It does cut out when it gets to a certain pressure but restarts as soon as there's a machine using it.
11/22/19       #5: Compressors ...
Bill Member
In our shop the compressor(s) does not turn off often if at all. There are spindles that constantly have air bleeding from the collet. A couple that are compressed air cooled and computer cabinet coolers that are always drawing air. The dust collector is always drawing big gulps of cleaning air. There really is not a time in our shop that the air demand drops below 50 CFM. We have a meter in the main line that gives real time CFM flow, very interesting to see.
The meters are not cheap but will give you a good look at your actual usage and help size your compressor correctly. We put ours in before we got new compressors and the information enabled us to buy the correct size. In the scheme of the cost over time I believe it pays off. Between the cost of the compressor, the maintenance and electricity it makes sense to really know your demand before you buy.
CFM Meter
11/30/19       #6: Compressors ...
cabinetmaker
We are running a VFD Gardner Denver for the stone shop and we may replace our non VFD rotary screw with the same. Very reliable and a lot less electricity wise than the timed cycle of the non VFD
12/2/19       #7: Compressors ...
Bill Member
Cabinetmaker. I am interested to hear about your experience.
Do you have a before and after example?
