Subject: Re: DXF code to Biesse works
1/13/20
Billy Lobb
i trying to put a finishing step on my code from autocad to biesse .My code that i using now is tch[rout](side)0(dp).005(thr)1
(tnm)$zc38$(vtr)3(dvr).015(shp)2 I would like to put a finishing step in code in there . Biesse manual said the code is (cof) and (dof) Enable finishing and Finishing step but it wont work for me . Any ideal what i doing doing wrong . Thanks
1/14/20       #2: DXF code to Biesse works ...
Dan
Try [routg] but if you already have three runs in a through cut and the last pass of .015, isn't it already done?
1/14/20       #3: DXF code to Biesse works ...
Billy Lobb
i want to get the 3 cut line out of side to clean it up.
1/16/20       #4: DXF code to Biesse works ...
Dan
The COF variable should work in a [routg]. Trouble is, in a perimeter cut, it's just going to add runs on the same path like the (vtr). It's more about bottom finishing and smoothing pockets.
We'll normally hog out a path to a skin and run a smaller tool in with horizontal step.
    • Limtech Industries, Inc.
