Subject: Re: Weeke Support Group
Weeke Support Group
1/14/20
Larry  Member
Hey Weeke users, Is there any support groups so we can provide support or tips ?
Either here or outside of the WW. If not lets start 1 !!
1/15/20       #2: Weeke Support Group ...
Alan F.
There is this one in Germany
https://forum.homag.com/forum/english
1/16/20       #3: Weeke Support Group ...
steve
The german forum (with an english subforum) is not great. tons of spam posts and mostly german posts. i try to help out there when i can (using a homag). i've gotten more help on this forum than that one (or the older archived woodwop forum).
1/16/20       #4: Weeke Support Group ...
Larry  Member
Specifically I am looking for assistance solving Error code 344 and 582
Thank you
1/16/20       #5: Weeke Support Group ...
Alan F.
Larry,
Error codes used to be in ~A1\NCWEEKE.TXT
344/80/ 'Rotation speed control of replacement tool'
I don't have 582
We no longer own a Weeke and I deleted a lot of the help files I had
1/16/20       #6: Weeke Support Group ...
Larry  Member
Thank you
1/17/20       #7: Weeke Support Group ...
I've often wondered why Stiles doesn't have one on their website. They have sold that unique machine for over 30 years.
10/15/20       #8: Weeke Support Group ...
Parasol Member
Not sure if it's related to Stiles. My guess is that it's related to Weeke ( Homag ). This company does it's best to make sure you depend on them for service. Try to replace a spindle on a recent 5 axis Homag and you'll see. You even need to input spindle serial number or identification in the controller, you can't just replace the spindle. Of course, you need Homag support ( $$$ ) to enter the serial number in the controller. This way, they can charge you whatever they like. And they do. We own 4 differents CNC brand, Homag ( or Weeke ) will cost you at least double for repair and you can expect to have problem with these CNC as much as with other brand.
3/6/24       #10: Weeke Support Group ...
Eamonn
Error
The led display is not responding to transmitted data.check communication connection
Note
Led is not being used and operator did not turn on/off
Any info greatly appreciated.
4/19/24       #12: Weeke Support Group ...
Ovidijus
Hello,
I have weeke optimat BP 150. After not working one week, i turned on it. And pc cant connect with num. Any ideas? I think Num battery was dead, but i changed that. But then i want to transfer programs to NUM, it not working...
7/14/24       #13: Weeke Support Group ...
Mark Member
Website: N/A
How to fix this problem on Weeke Vantage 21s. Error Code 37 and 344
after I setted the tool number in a program it is missing /gone during running operation.
View higher quality, full size image (3000 X 4000)
8/12/24       #14: Weeke Support Group ...
Michael
We have a BP 80 and when i try to use the pocket rout command i get a error code 93 , Trying to figure out the cause and reason and if it is something i can fix. Other then that the machine runs fine.
View higher quality, full size image (3024 X 1701)
