Subject: Re: buying a used Biesse skill 2014
2/12/20
paul Member
I am looking a buying a used Biesse skill it is a 2014 model and has been used for door production.it is going to be our first CNC.what would you check ? how do I check hours? have you got one and what are the quirks these machines have? how many hours are expected on a spindle life.
I am trying to get Biesse to do an inspection but the time frame may be to tight and I will have to do myself .
2/12/20       #2: buying a used Biesse skill 2014 ...
Mark T.
Hours can be partially checked within the Statistics environment , if enabled on the control. Spindle life varies, as you would expect, due to use. A machine running in a larger company with multiple shifts, generally will not have faired as well as a machine in a one shift cabinet shop that may have ran it 10~15 hours a week. HSD spindles are very good spindles and used by multiple manufacturers even though they are owned by Biesse. Depending on use these spindles can last for a decade or more before they need bearing replacement. Some models are better than others. It's best to inspect while still under power, if possible. Focusing on safety features, wear on rails, racks and ball screws, obvious damage to guarding, table condition, spindle and boring unit condition , vacuum system condition.
Hope this helps!
Mark T.
2/18/20       #3: buying a used Biesse skill 2014 ...
It has been used in door production. As in MDF doors? Was it in a door shop?
