Subject: Re: kerfing method option for cnc router
3/31/20
Ian
Hello, our home built automated radial arm kerfing saw is about to spit out its bearings, and we can't find replacements. We have a 5 axis router that we could use to do this operation, but I am looking for the best option on a budget. I see that we can get fancy stacked arbors with multiple blades, but this isn't a great time to spend $$$. So basically my question is- do we just do it the traditional way with a single saw blade, or would a 60 degree small diameter router bit provide a higher quality cut? I realize the kerfs will need to be reasonably close, but trying to avoid blowout.
4/1/20       #3: kerfing method option for cnc route ...
Collin Parker  Member
Website: heritagewoodwright.com
the 60degree would certainly make cleaning up the grooves for finishing significantly easier as there would only be one easier to sand corner as opposed to a flat bottom with two 90degree corners to sand
4/1/20       #4: kerfing method option for cnc route ...
Chuck Hicks Member
Insert V Groove Bit is the way to go
View higher quality, full size image (2110 X 1288)
4/1/20       #5: kerfing method option for cnc route ...
It would be nice if we knew what material you were machining.
4/2/20       #6: kerfing method option for cnc route ...
Ian
Material is 3/4 oak veneered plywood for radiused stair risers.
4/2/20       #7: kerfing method option for cnc route ...
Seems like it would be better to order the material from a supplier that has the machine to do this?
4/2/20       #8: kerfing method option for cnc route ...
Ian
No, we would need to make these risers in house, we have multiple custom jobs per week. We have a single saw blade for our 5 axis, but that machine is usually tied up.
4/2/20       #9: kerfing method option for cnc route ...
BH Davis  Member
Instead of kerf cutting have you considered making a laminated glue up from two layers of 8 mm bending ply? Or 3 layers of 5 mm bending ply if the radius is too tight for the 8 mm. You could apply a veneer layer at the same time.
This is pretty easy to do once you've got the feel of the process.
4/2/20       #10: kerfing method option for cnc route ...
Definitely in-house just judging by what machinery you’re possess. I’d definitely try the v groove and if u don’t like it slap on a 3/16 or 1/8 downshear and it’ll match the saw blade kerf style. Personally I prefer using 3/16 over 1/8 when I can, I feel they are much more durable and less prone to snapping even just 1/16 wider.
4/3/20       #11: kerfing method option for cnc route ...
Thomas Gardiner
The cnc will be too slow. Rebuild the bearings. Or you can pickup a good used radial arm saw for cheap then you can consider a stack of blades and spacers. Or custom ground blades with a taper.
4/3/20       #12: kerfing method option for cnc route ...
Kerfcore and put an Oak veneer on it.
    • Limtech Industries, Inc.
