Subject: Re: Giben G65 with G57 software
3/24/20
Hi All.
Just installed a new to us Giben G65 and am having a little trouble programming some strips.
All I want to do is cut a 4X8 sheet to 1727mm length then rotate it and cut strips of 108mm wide.
The programming examples I have start with a head cut the length of the sheet and then rip cuts. I think I want to do a head cut then a crosscut but it won't allow it.
What am I doing wrong?
3/25/20       #2: Giben G65 with G57 software ...
Rob Young  Member
Website: nutekmachinery.com
Head cuts are designated as 2
Rip cuts are designated as 3
Cross cuts are designated as 4
W cuts are designated as 5
and Z cuts are designated as 6
The numbers have to follow each other when programming and you can't skip. For example if you program a head cut (2) you have to follow it with a rip cut (3) before you can do a cross cut (4). After doing a head cut (2) you may have no material to cut on the rip (3) so you enter the full value of the panel size for your rip cut value before progressing to a cross cut (4). I'm not certain this is going to accomplish exactly what you want because I'm not certain exactly what it is you want but this is the basic guideline you have to follow when programming cuts. Some of the software also had an option that allowed you to input the part sizes and quantities you want to cut. You would then press the optimize button and the software would lay the parts out on the panel for you. The software you are using hasn't been used in a while. I would have to physically lay eyes on it to go more in depth on how to use it.
3/25/20       #3: Giben G65 with G57 software ...
Hi Rob.
OK, that makes some sense.
So if I want to make a long cut first I would do:
2 full length 1
3 full width 1
4 desired length 1
3/25/20       #4: Giben G65 with G57 software ...
Rob Young  Member
Yes, that should work.
3/26/20       #5: Giben G65 with G57 software ...
Yup.
Thanks.
4/3/20       #6: Giben G65 with G57 software ...
Another small annoyance:
I am trying to cut a 130mm wide by 1500mm long part into 50 25mm by 130mm strips.
I have followed the sample in the programing manual exactly and I get a correct picture of how it should look,
but I get an error saying that I have an impossible pattern.
Any ideas?
4/3/20       #7: Giben G65 with G57 software ...
Rob Young  Member
How many 25mm pieces are you cutting out of the 1500mm? You may be trying to cut to many of them. You need to calculate the saw kerf for each cut you make and there is likely mandatory trim cuts that need to also be calculated. You can't exceed the 1500 mm with the sum of your measurements.
2/20/23       #9: Giben G65 with G57 software ...
Dan Hudzinski
Website: http://dtmmachine.com
Sorry for the late response. My guess is that you're running into a gripper clearance issue with the final 25mm piece. The gripper feet are a bit longer than that and would interfere with the blade during the second-to-last cut. The machine wants to release its grip so it can move the grippers back and out of the way of that cut, but there is also the last trim cut to be performed afterward. Since it opened the grippers and pulled back for the second-to-last cut, the pusher has "lost control" of that last piece and thus will not perform the rear trim cut.
You end up losing one piece, but the solution for that series of 25mm strips is to program the final piece as something larger, such as 1.5". I don't recall the exact 'safety' dimension but it's somewhere in the 1.5" - 2.0" neighborhood.
For your original question, if you want to just go straight to cross cuts instead of doing head and rip cuts, then I believe G57 allows you to skip the 2 and 3 cut codes and your first line could start with a code 4. If it doesn't allow that, than Rob's solution would do the trick.
    • Machinery Associates
    • Country Saw and Knife
