Subject: Re: MDF Doors- Corner squaring
5/10/20
Chris
I've been making MDF doors on my cnc for a few years now. Most of them are flat panel doors with either a square, fillet or beveled edge profile.
When I make a door with a beveled inside edge using a v bit I exit the corners on a 45 degree angle, ramping up on the same angle as the tool geometry to square up the corner.
My question is can this technique be used in a non square profile ( think of a range hood panel with the sides sloping in, or a door with an arched top rail where the profile transitions from an arc to a straight line). If so how is the geometry calculated as I assume the exit angle would not be 45 degrees? Any advise is appreciated. Thank you
5/11/20       #2: MDF Doors- Corner squaring ...
Bob Lewis Member
With Cabinet Vision Door Maker you can
5/13/20       #3: MDF Doors- Corner squaring ...
yaakov
sure can be
this sample from our software
the geometry calculate is ,you make offset out to yours base shape(the amount is depened tool angel)
then conect the corner points from base to offset
hope its clear
yaakov
View higher quality, full size image (842 X 667)
5/31/20       #4: MDF Doors- Corner squaring ...
Ian
What software are you using?
