Subject: Re: Chamfer vs Radius? CNC or Trimmer?
6/1/20
Jeff Member
Hi folks!
I am working on a design that will be cut on a CNC router out of 18 mm (3/4") birch plywood. Parts will be glued fact to fact to make 36mm parts later, using dowel pins. They have to be glued up afterwards due to internal features.
I want to ease the edges for appearance and also to clean up any tabs or onion skinning.
Is it easier to use a chamfer vs roundover (1/8" or 3/16") in a production environment? I'm leaning towards roundover, but I know it can be finicky on the height adjustment to be a smooth transition.
Also, is it worth doing on the CNC? The vast majority would have to be undercut. I figured that would be possible with a bit like:
http://www.harveytool.com/prod/Chamfer-Cutters/Specialty-Profiles/Browse-
Our-Products_194/Chamfer-Cutters---Back-Chamfer-Cutters_250.aspx
Thanks!
-J
eff
6/2/20       #2: Chamfer vs Radius? CNC or Trimmer? ...
I a not sure what you mean by undercut but I believe over time a chamfer appear more uniform and show less variation due to inconsistent material thickness and or warped material.
Good luck with your project.
6/2/20       #3: Chamfer vs Radius? CNC or Trimmer? ...
Mark T
Website: http://www.cncustomservices.com
While you reference as a bit, the Harvey cutter you showed is designed to cut ferrous metal, similar to an end mill. This is not to say it cant cut wood, it probably can. The problem is the rake and lead angle of the cutting face are ground entirely differently than router bits for the added strength needed to cut harder materials. The short answer is you "may" be able to use it for your application, or you may not. If you are onion skinning because the parts are very small, using a tool to cut underneath the part is a crap shoot. It will provide "lift". Strictly on the cutting through the onion skin issue - I have had the best results by coming back with a smaller diameter cutter a few thousandths of an inch off the edge of the profile. If the cutter leaving the skin is 1/2" or 3/4" I would come back in with a 1/8" diameter bit and break through with that. Hope this helps. Mark T.
10/18/24       #4: Chamfer vs Radius? CNC or Trimmer? ...
cncmuchman Member
In a production environment, chamfering and rounding have their own advantages. Chamfering is usually easier to achieve, while rounding may require more skill and adjustments to achieve a smooth transition. Your preference is to use rounding, which may require more attention and skill to ensure the quality and appearance of the edges.
It is generally worthwhile to perform such machining on a CNC machine, as CNC can provide high precision and repeatability, ensuring the quality and accuracy of each part. Make sure to consider factors such as tool diameter and path planning during the design phase to achieve the best machining results.
https://www.want.net/choosing-the-right-chamfer-bit-for-optimal-cnc-edge-processing/
    • Machinery Associates
    • Country Saw and Knife
