Subject: Re: right bit for acrylic
6/19/20
duster
I need to cut a 24" diameter circle out of 1/2" acrylic for an art pedestal. What type of bit would work best, and what would be a recommended rpm and feed speed? Thanks!
6/19/20       #2: right bit for acrylic ...
Quicktrim
I have used several from vexor tool and they have worked very well and they have great tech support to set your feed and speed.
6/20/20       #3: right bit for acrylic ...
1/4" or 5/16" single flute O flute from any reputable company. Two to three passes. Final pass allowance of .010" or something like that.
6/20/20       #4: right bit for acrylic ...
james e mcgrew  Member
Hoprfully it id cast acrylic, test oass on offall before you cut actual peice try .25 upcut O flute 100 IPM at 9 k rpm at .0625 deep
what you are looking for it the chips to flake and not melt onto bit.. if it wraps the bit or melts on do not proceed with final work
6/21/20       #5: right bit for acrylic ...
Jim Anderson
I have cut a lot of acrylic. Use the formula from LMT Onsrud. 63-700 series 1/4" Spiral O flute Upcut 20,000 RPM 200 IPM 2 passes. I also use a mister with alcohol in it to keep it cool, it evaporates and leaves a really good edge finish.
Hard_Plastic.pdf
O flute
6/21/20       #6: right bit for acrylic ...
jerry Member
I have used both 0 flute and a Vortex low helex and I like the Vortex better
6/21/20       #7: right bit for acrylic ...
duster
Thanks for all the responses! I found a 3/8 hss O flute bit in a drawer that I don't think I've ever used. Do you think that might work? I'd definetly try it on some scrap first. If that's not a good idea, I'll buy one the bits recommended here. It makes sense that an upcut bit might be the best choice.
6/30/20       #8: right bit for acrylic ...
Paloma  Member
There are router bits especially for acrylic cutting. Here is the product link. Hope it will be helpful for you.
Router Bits
10/14/20       #9: right bit for acrylic ...
duster
Finally got to this project today. I used James's guidelines, a new 1/4" upcut spiral O flute @ 9k rpm & 100 ipm. The plexiglass cut perfectly. Thanks for the help!
    • Biesse America
    • SainSmart
      CNC and Engraving machines for Makers
    • Limtech Industries, Inc.
