Subject: Re: Nesting CAM
Nesting CAM
8/30/20
Good afternoon.
The time has come to upgrade my nesting/CAM software.
I'd like the ability to nest solidworks and similar assemblies as well as dxf files.
Need posts for Biesse Arrow, Rover and Andi.
Any recommendations? Already looking at Alphacam and Mastercam. There must be others.
9/1/20       #2: Nesting CAM ...
jerry Member
Not sure if Vectrics Vcarve Pro would work for you. You can download a working trial to see if is a fit
9/1/20       #3: Nesting CAM ...
Johann Huck
Website: http://www.tmwsales.com
I would look at Cim-Tech Router-Cim. They can nest from Solidworks.
https://cim-tech.com/solid-cim.html
Another option would be EnRoute. They both can take CAD files and nest them and post to most CNC machines.
https://www.thinksai.com/products/enroute
9/2/20       #4: Nesting CAM ...
I would also check out Cim-Tech. They have been around for a long time.
9/2/20       #5: Nesting CAM ...
pat gilbert
Cadcode
9/2/20       #6: Nesting CAM ...
routalot Member
Vcarve would do the job and isn't hugely expensive.It also comes with a good number of post processors.
9/10/20       #7: Nesting CAM ...
Ian
I see Alphacam 2021 has a nested solids feature. I haven't used it yet, but pretty straight forward. Can also cut solids tool side from a simple rough finish function.
10/14/20       #8: Nesting CAM ...
yaakov
with knest i think i can give you the best solution
    • Better Vacuum Cups, Inc.
    • Country Saw & Knife
