Subject: Re: what a good bit to hollow out out shaker door
7/9/20
farmer billy
I need recommend on a bit to hollow out one piece shaker middle . I know everybody got fravorite . Thank
7/9/20       #2: what a good bit to hollow out out s ...
RichardP
What did the shakers use?
Flat panel. recessed panel. This shaker thing has gone on far too long!
7/9/20       #3: what a good bit to hollow out out s ...
I bought an Amana RC-2250 for hogging out most of the material. Max 1/4" depth per pass, so I'm doing the panel pocket in two passes. Then chase the perimeter with a 1/2" down, 1/4" down, then an 1/8" down.
You'll want to offset that insert tool a bit from the perimeter, the inserts sitting almost flat will knick the inside edge of the pocket otherwise, and if pocketing from the inside out, when the tool withdraws, it will rip up that edge if it withdrawals vertically.
I think it likes a fairly long ramp as well.
7/10/20       #4: what a good bit to hollow out out s ...
Dan
Vortex 8300 insert set works.
8/31/20       #5: what a good bit to hollow out out s ...
farmer billy
do you have any trouble with tearout on the panel we call them pits dont show up until u primed them
9/9/20       #6: what a good bit to hollow out out s ...
Dan
No problem.
Mill in 2 passes with .5 to 1mm for the finish pass. Pretty much eliminates the "pitts".
    • Limtech Industries, Inc.
