Subject: Re: Starting my cnc after a month of lockdown
10/19/20
Alain Member
Hello all hope your doing great
Any tips on the healthiest way to start using my cnc after a month of shutting down?
Any tips will be much appreciated
Thank you in advance
10/20/20       #2: Starting my cnc after a month of lo ...
A month offline should not affect a machine. I have seen dry rot of airlines and corrosion build up on machines that have been down much longer than that. Just make sure the incoming air is dry and you have oil in the air oiler. You might check the tool holders for any corrosion and clean them appropriately.
2/23/22       #3: Starting my cnc after a month of lo ...
Carter Asco
I think the lack of a square edge to glue to will cause issues we haven't even discussed..
    • Machinery Associates
