Subject: Re: Text
Text
11/3/20
Silly questions but...
I doing a lot of parts with text on them. Mostly block or similar.
I'm getting frustrated with all the ups and downs and short lines. Sometimes the text is 1/3 of the total machine time.
Anyone out there know a good single line cursive text that could work instead? To make the WVRA06 into one line instead of 14 or 15..
11/4/20       #2: Text ...
The only way I've had success is having to manually edit the text. If it's a generated label type affair (constantly changing) ive not found a simple way to clean them up.
11/4/20       #3: Text ...
I had a couple pages bookmarked when I was trying to get a fast single line font for labels and you may think about creating your own font something like the Kabel font on this page. You'd still have the retracts from one letter to the next but you'd only have a single plunge/retract for each letter.
Single Line Fonts
11/4/20       #4: Text ...
Jared
I don't know if this would work in reality, but it does in my head and might be worth exploring. Use a single line cursive script font in autocad, then use express tools to explode the text into arcs & lines, then PEDIT and join the results into fewer polylines.
    • Biesse America
