Subject: Re: cabniet vision tool overlap percentage
11/10/20
shane Member
Good day, I'm running cabinet vision version 11. Running 1 PC mdf doors, CV is setup for 50 percent tool over lap and this appears to be fixed. Is there any way to increase tool overlap percentage? What is everyone's practices to achieve an smooth finish. I'd like to be able to take it from the machine straight to the paint booth, with no sanding.
11/10/20       #2: cabniet vision tool overlap percent ...
I dont run CV or a 50% stepover but id say if its not working you either need to look at your tooling (rad on the edges) or your tram. 50% is a magnifier of either issue.
11/11/20       #3: cabniet vision tool overlap percent ...
Machine to spray isn't going to happen unless you use the CNC to sand and even then there will need to be some touch ups by hand.
11/11/20       #4: cabniet vision tool overlap percent ...
Shane
When I use machine software, machine to spray is no issue at all. I'm able to create a near perfect surface. Just a little touch up after priming. Just when I use cabinet vision, I'm unable to manipulate the tool path. To achieve the same surface
    • Machinery Associates
