Subject: Re: Anderson cnc
Anderson cnc
12/22/20
stevej2021 Member
I work for a guitar mfg. in Northern California, we have 2 Anderson Stratos/Nest cncs in the winter I have consistent problems with photo sensor stops and it seems like its a thermal issue where there might be a loose connection somewhere and after the machine/building heats up the problem diminishes. Does anyone experience this issue and any suggestions would be helpful.
12/23/20       #2: Anderson cnc ...
Charles Wright  Member
Website: http://www.northcreekwoodworks.com
We run a couple of Andi's also, not the Stratos however. When we have issues we do our troubleshooting for a limited period of time, then we call Anderson directly. They know their machines and generally make suggestions quickly.
Let us know what you discover..
12/24/20       #3: Anderson cnc ...
Point a radiant heater at the sensors in question on cold nights....
Could just be the sensors are getting old.
Do you have a wiring diagram?
12/28/20       #4: Anderson cnc ...
stevej2021 Member
We have started to leave power on overnight and have started to point a heater at the control box, I will try pointing the heater at the sensor towers themselves. Thank you for the input.
Steve
    • Limtech Industries, Inc.
