Subject: Re: Scm Pratix48 side rail issues
1/15/21
I have a Pratix48, their is a rail on the back side of the table parallel to the X axis that is connected to 4 cylinders, There are 3 cylinders on the end that are parallel to the y axis. These pins and the rail are stops to push your material against and are 0X and 0Y. When you turn your vacuum on at the table this rail and these pins will automatically drop.
The problem I am having is the 3 pins will drop but the rail and 4 pins will not drop now. I was wondering if anyone has had this problem? How was it fixed? Or any other input. Thanks
1/15/21       #2: Scm Pratix48 side rail issues ...
Simple things first.
Does the machine have an FRL and if so, is the oil level always kept up?
Is there some kind of mechanical issue that keeps it from dropping?
Can you push it down?
When it's supposed to go down is the air pressure to the cylinders on the correct line?
If not, will it go up and down when the solenoid is manually actuated?
Are there proxy's on the cylinders? Are they reading accurately?
Etc.
    • Better Vacuum Cups, Inc.
    • Palmetto Cabinet Doors
