Subject: Re: Cutting plastic material
1/28/21
I would like to build some plastic slides to run a saw down. I would like to build them out of some sort of plastic, I need them to be durable, not brittle and act as a strait edge so durable. The longest I would need is 8 ft. The reason I want some kind of plastic is they will get wet.
My questions are?
What material do you recommend?
What feed and tool speeds do you recommend?
What tooling do you recommend?
View higher quality, full size image (2828 X 1276)
1/28/21       #2: Cutting plastic material ...
UHMW, HDPE, or solid surface drops if you have a shop close by that would give you some would be my suggestion. A lot depends on your availability and your budget.
1/28/21       #3: Cutting plastic material ...
PS. Tooling and feeds/technique would be highly dependant on what machinery uou have. Simple profile like that could be run on any number of tools.
1/29/21       #4: Cutting plastic material ...
Peter Matos
Well if you only intend to slide things across it and not have to glue anything to it you might try starboard, its very slippery and dense plastic. It takes screws etc but just not much for gluing to... Good luck man.
Pete
1/29/21       #5: Cutting plastic material ...
MarkB,
Thanks for the info, I have 3 sheets of some fairly dark grey material, it came in a lift of misc material I bought from a shop that was closing down. I have no idea what it is though, there is no markings on the edges and it may take a while to move material to see the faces.
Pete,
We used some of that starboard for countertops in a bar, once upon a time, I totally forgot about that stuff. We used 3/4 inch and cut everything on a saw, how does it machine on the cnc?
1/30/21       #6: Cutting plastic material ...
Thomas Gardiner
Umhw. hdpe, and Starboard may not be rigid enough to act as a straight edge. It will flex in the middle if it is clamped only at the ends. Phenolic would be a better choice but I would make it out of two layers of 1/4" thick that is screwed together. Phenolic can be tapped for machine screws.
1/31/21       #7: Cutting plastic material ...
pat s gilbert
Is there a reason you can't use a track saw?
2/1/21       #8: Cutting plastic material ...
rich c
No such thing as a plastic straight edge. The slippery materials recommended will sag under it's own weight. Time is profit. But a track saw and make money. Dinking around to save money on machinery is lost profit.
2/1/21       #9: Cutting plastic material ...
Oggie Member
I have 1/4" thick, 4-1/2" solid aluminum bar, a little over 8' long and it sags in the middle when sliding handheld router against it, unless I put additional one or two clamps in the middle.
I doubt the plastic will do the work.
2/3/21       #10: Cutting plastic material ...
Thanks for the input, I will just use a piece of plywood and throw it out when we are done. I figured if I cut some plastic straight/edge slides on the cnc, I could use them and then put them in the racking if I ever needed them again.
Renovating a kitchen and the cabinets in one spot are up against a knee wall and the granite top runs over the top of the knee wall . The wall needs to be built up to add upper cabinets, lower cabinets to be modified and top to stay in place
We just need to cut 4 1/2 inches off the top.
I have a Festool track saw but that is not the tool for this job, the top can be cut in place. The stone guy is to busy to do the work.
Thanks again for all your input.
2/3/21       #11: Cutting plastic material ...
rich c
Famous last words, "The stone guy is too busy, I'll cut it myself, what could go wrong?"
